Nextion with Arduinno
rclevers
Post by rclevers »
I need a little bit help.
I try to get the value from n0 and put it in n1.
What happens is:
first cycle the value from n0 is in n1
second cycle the value from n0 is in n1
third cycly value from n1 is 0
fourth cycle the value from n0 is in n1
After that the value of n1 is 0 till I make a reset.
My problem is to need the command GetValue in the Nextion library.
SetValue is working very well if I try it in another way.
I have checked it with Arduino Uno, Mega and mini.
Thanks for help
Readwrite.fcfx
(9.77 KiB) Downloaded 509 times
read write.odt
(361.31 KiB) Downloaded 506 times
Wolfgang_Kos
Re: Nextion with Arduinno
Post by Wolfgang_Kos »
I have the same problem, I don´t can read the values, do you you solved this problem now, thanks.
