adc problem PIC24FJ128GA204
asmatec
Been thanked: 4 times
Post by asmatec »
Hello, we continue with the problem of the adc inputs on the pic24fj128ga204 chip, this is the message when compiling to hex!
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c: In function 'FC_CAL_ADC_Enable_1':
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c:823:29: error: 'ANSELA' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c:823:29: note: each undeclared identifier is reported only once for each function it appears in
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c:1226:14: error: 'AD1CON2BITS' has no member named 'VCFG1'
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c:1227:14: error: 'AD1CON2BITS' has no member named 'VCFG2'
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c:1230:15: error: 'AD1CON2BITS' has no member named 'VCFG0'
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c:1232:15: error: 'AD1CON2BITS' has no member named 'VCFG0'
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_ADC.c:1244:14: error: 'AD1CON1BITS' has no member named 'AD12B'
CRG_PIC24_V1.1.c: In function 'main':
CRG_PIC24_V1.1.c:5778:3: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:542:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
CRG_PIC24_V1.1.c:5779:3: warning: passing argument 1 of 'FCI_LEFTSTRING' discards qualifiers from pointer target type
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:170:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
CRG_PIC24_V1.1.c:5779:3: warning: passing argument 4 of 'FCI_LEFTSTRING' discards qualifiers from pointer target type
CRG_PIC24_V1.1.c:5785:3: warning: passing argument 1 of 'FCD_0be11_LCDI2C1__PrintString' discards qualifiers from pointer target type
CRG_PIC24_V1.1.c:4994:6: note: expected 'MX_CHAR *' but argument is of type 'volatile MX_CHAR *'
CRG_PIC24_V1.1.c:5797:2: warning: 'return' with a value, in function returning void
regards.
Miguel.
Has thanked: 800 times
Been thanked: 866 times
Re: adc problem PIC24FJ128GA204
Sorry, this has slipped under our radar.
This will be looked into ASAP
Has thanked: 177 times
Been thanked: 1027 times
Post by mnfisher »
See also viewtopic.php?f=5&t=2190
Sorry for the delay, I have been on holiday.
Would you like to test your project with the attached file?
Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
24FJ128GA204.fcdx
(44.55 KiB) Downloaded 776 times
