PWM issue with ATMEGA8A
artan
Post by artan »
Hello, I want to get a PWM signal out at port B3 of a ATMEGA8A. This port uses Timer2 for PWM signal.
The other two ports PWM B1 and B2 use the Timer1.
Unfortunately that doesn't work. In a test program that enables only PWM ports and then sets DutyCycle at 255, B1 and B2 turn on, B3 doesn't.
Has thanked: 435 times
Been thanked: 651 times
As your issue is not to do with the PIC16F1825, you really should have created a new post.
Also, you will need to attach your file for anyone to help.
Has thanked: 713 times
Been thanked: 775 times
Re: PWM issue with ATMEGA8A
chipfryer27 is correct.
Please don't hijack other people's topics.
I have created a new topic for you.
