Can´t finish Flowcode 10 core update
ssttrragmail
Has thanked: 18 times
Been thanked: 2 times
Post by ssttrragmail »
Hello FC Users: I´ve been receiving successive error messages when trying
to download the core update file "Flowcode V10_QFE4_10.0.4.33.msp".
Could you please help me overcome this issue ?
Thank you.
download error 1.jpg (184.45 KiB) Viewed 18017 times
download error 2.jpg (181.65 KiB) Viewed 18017 times
kernel file.jpg (201.85 KiB) Viewed 18017 times
Has thanked: 306 times
Been thanked: 471 times
Re: Can´t finish Flowcode 10 core update
The full download on our website should be the latest version and so I suggest you uninstall and reinstall Flowcode using the full installer downloaded from this page. Your settings should be retained when you re-install.
ssttrragmail
Ok, but just to confirm before completely uninstalling process:
was the last kernel version of FC10 published after JUNE/23 ?
Thanks.
my current version.jpg (20.93 KiB) Viewed 17985 times
Has thanked: 471 times
Been thanked: 701 times
FC v10.0.4.33 built July 25th 2023
ssttrragmail
I still can´t install FCv10.
Throught the website I can start download the "FlowcodeV10.Installer.msi",
but at the end of this process it is simply deleted from the PC (!?) and replaced by a "process_dl.php" (112 bytes)
and yet another CRDOWNLOAD file "Not confirmed 422266.crdownload" (226.392 KB) !!??
What could be preventing the ".msi" from being recorded, and what are these other files that appears immediatly
afterwards ?
What anti-virus are you running? You may need to manually add it to a "safe" list.
ssttrragmail
I use Kaspersky, but it was not the cause of all the confusion I mentioned at the beginning of this post.
You know that sometimes we ourselves create unexpected and completely unknown traps when we slightly vary the way we do certain things. When things are getting complicated, it's because you've already missed the answer or the correct path.
So I reluctantly decided to follow the suggestion given above by Steve-Matrix, and uninstalled all of FC10 and downloaded the version through the path he indicated. Previously I had downloaded it another way... This was the trap.
And in fact this time I managed to install the version that you´ve mentioned, all fluently and without surprises.
I thank you.
