Toggle output pin function
RGV250
Has thanked: 46 times
Been thanked: 46 times
Post by RGV250 »
In the software I use for PIC microcontrollers there is a "toggle" function where every cycle the bit inverts which is very useful for an LED in a loop.
I can write it myself but just thought it might be a useful addition to have a toggle bit / output pin option. (If it does not already exist of course)
Bob
Has thanked: 291 times
Been thanked: 458 times
Re: Toggle output pin function
You can reference port and pin values directly in Flowcode using the "$" symbol, so it is trivial to toggle a pin.
For example, to toggle pin B3, you could either use a calculation icon with the following code:
$B3 = !$B3
or
$PORTB.3 =  !$PORTB.3
Or alternatively use an Output icon and output the value "!$B3" to pin 3 on PORTB.
