Rotary encoder + led r and led l
solozerouno
- Has thanked: 2 times
- Been thanked: 2 times
I'm creating a project with Arduino Uno that manages two rotary encoders and 4 LEDs, two green and two red: each encoder drives the two LEDs, one green and one red based on whether the rotary encoder turns left or right. the second encoder works like the first with the other 2 LEDs.. please help me.... it's urgent. Thanks solozerouno
- Has thanked: 434 times
- Been thanked: 650 times
Re: Rotary encoder + led r and led l
Unsure of what help your are requesting. Many examples of using encoders on the WiKi and it would be simple enough to modify to include flashing an LED
solozerouno
my project requires that an output: led1 has a pulse at each click of the rotary encoder and if it turns to the left and led 2 or output 2 if the rotary encoder turns to the right.... it's can you help me with a simple example please. ... Thanks solozerouno.
solozerouno
Please help me....
solozerouno
The wiki has examples of using encoders https://www.flowcode.co.uk/wiki/index.p ... ral_Input)
You should be able to modify to include flashing a LED depending on if the value increases or decreases.
