I need help to solve this problem ASAP
it seems that there is overflow of the variable when make this calculation
51569*2=37602 instead of 103138
I think it's overflow because 103138-65536=37602
But the calculation result is store in ULong variable
May be I did something wrong !
Thx for your prompt help
Urgent Variable overflow in calculation
Xbiotec
- Has thanked: 37 times
- Been thanked: 27 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: Urgent Variable overflow in calculation
What if you do the following in a calculation icon?
Or alternatively, you could try making the Max_Flow_Var also ULONG instead of a BYTE.
Both of these should force the compiler to perform the calculation without truncating to a UINT.
Max_Flow_Time = Max_Flow_Const
Max_Flow_Time = Max_Flow_Var * Max_Flow_TimeBoth of these should force the compiler to perform the calculation without truncating to a UINT.
Xbiotec
this work
thx
Max_Flow_Time = Max_Flow_Var * Max_Flow_TimeSeb
