PIC24FJ1024GB610 I2C Channel3 problem
Sasi
Has thanked: 43 times
Been thanked: 15 times
Flowcode v10 PIC24FJ1024GB610 I2C Channel3 problem
Post by Sasi »
Happy New Year to everyone!
I tried the SHT-31 sensor on the Clicker2 panel.
The MCU type is PIC24FJ1024GB610.
If I select Channel 3 in the "Grove Component SHT31" Component Properties window, I get the attached error message from the compiler.
Sasi
PIC24FJ1024GB610 I2C_test.fcfx
(16.05 KiB) Downloaded 350 times
Has thanked: 264 times
Been thanked: 424 times
Re: PIC24FJ1024GB610 I2C Channel3 problem
It looks like there is an issue using Channel 3 for the I2C for this chip. If you change this to Channel 1 or 2 (or use software mode) then it should be ok.
Sasi
Post by Sasi »
That's right.
There is only a problem with channel 3.
But I don't think it's a chip bug because I get an error message from the compiler about references to undeclared variables.
