Power monitor
Sparky
Power monitor
Post by Sparky »
The attached embedded file is included in the apps area of the wiki. I am using v10 of flowcode . When i try to compile it comes up with syntax error
1212. The esp 32 wroom is the target. Any thoughts on this?
Mains PMon v1.0-ESP32 Wroom Firmware.fcfx
(29.86 KiB) Downloaded 402 times
Has thanked: 756 times
Been thanked: 819 times
Re: Power monitor
Hi Sparky.
There is a new revision (updated for Flowcode v10) of the firmware which you can download from here.
Although the one you downloaded will compile OK, but will not look good in Flowcode v10 as it was created with Flowcode v9
When you see just the words syntax error, that usuaslly occurs when the is a pin connection that has not been made.
Check the Modbus pin connections which are shown within documentation from the above link
