There is no config setup to disable the MCLR pin.
Is there a way to disable MCLR pin using C code or any other means except or a pull up resistor .
Thank you
18F8520 MCLR pin
Roy_Johnston
Roy_Johnston
- Has thanked: 575 times
- Been thanked: 757 times
Re: 18F8520 MCLR pin
I'm afraid the MCLR pin pullup to VCC is required on this device, there is no way to disable it in software.
If you have a PCB designed without the pullup then there may be a pin compatible device you can use which does offer the internal MCLR feature.
