After the latest definition file update for the Arduino Nano (57600) - the command line for AVRDUDE is incorrect.
H:\>"H:\AVR\avrv5\batchfiles\..\bin\avrdude.exe" -p m328p -P 57600 -b "H:\Flowcode1.hex" -c arduino -D -U flash:w:""
avrdude.exe: invalid baud rate specified 'H:\Flowcode1.hex'
Should be -b 57600 NOT -P 57600.
Upload problem on Arduino Nano 57600
- Has thanked: 158 times
- Been thanked: 943 times
- Has thanked: 102 times
- Been thanked: 299 times
Re: Upload problem on Arduino Nano 57600
Hi Martin,
Did you select the programmer port setting in Build -> Project Options
It needs to be explicitly set, even if displayed in the drop list, then click "Modify"
If you still have issues please get back to us.
Hi Leigh,
- Maybe - will check. That's a change - nothing in port instead of the COM3 or whatever.. Would explain why everything shifted left one place...
