dht22 update with possible problem
aderito
Has thanked: 19 times
Been thanked: 2 times
Post by aderito »
Hi, after updating this sensor's library I started having problems in a project I'm developing and where I'm using this dht22.
I went to the component library and changed it to the previous version and then it started working correctly again.
I hope to help someone with the same problem and also the programmer find the solution.
in the return variable of the "samplesensor" macro I get the number: 79.
I don't know if it helps anything..... :?
Has thanked: 278 times
Been thanked: 445 times
Re: dht22 update with possible problem
Sorry about that. What target chip and clock speed are you using?
And you can revert the version of the component via the Library Updates screen (tick "show up-to-date files" and select "6" in the "New revision" column).
Has thanked: 713 times
Been thanked: 775 times
Can you read this post, please.
aderito
Post by aderito »
Steve-Matrix wrote:
Mon Feb 12, 2024 10:48 am
Hi Steve, sorry I'm only replying now, I've been away at work and without my hobby bench.....
I'm using a pic18f4620 running at 40Mhz.
In the dht22 component I was already using the groove version when an update appeared and it was after updating that it stopped working.
After that I reverted to the previous version and it worked again...
