Defaults for custom macro parameter field(s)
Brendan
Has thanked: 64 times
Been thanked: 17 times
Post by Brendan »
When working with macros it is required to re-enter input values in all parameter fields every time.
However, I'm finding that if it were possible to set editable default value(s) within the macro itself (i.e. highlighted default entries specified in the macro edits), then could save considerable time (particularly when working with many macros and input parameters) having to re-state common entry values whenever such macros are dropped into the parent thread.
Obviously, without such defaults, parameter entries would simply appear blank/required, as they currently do.
Many thanks,
Brendan
Has thanked: 264 times
Been thanked: 424 times
Re: Defaults for custom macro parameter field(s)
That is a great suggestion - thanks.
