This has now been fixed, so you will need to do a Full database component update, then reload your project.
To do a full component update, when you run a library update via Help > Library updates..., you must change the Files in-use to Full database.
UART, I2C, SPI that don't retain pins in software mode
- Has thanked: 646 times
- Been thanked: 704 times
- Has thanked: 201 times
- Been thanked: 225 times
Re: UART, I2C, SPI that don't retain pins in software mode
Hi Martin
Very good. Thank you very much.
Can you please also improve the hardware channel.
So that this is also saved.
For example the component:
LSM9DS1_AccelGyroMagnet1
Hi Bob.
The components fixed are available within the Full database updates.
If the component you are using has not been updated, then we need to look into what the issue is.
Thank you for bringing it to our attention
