DAC output not appearing on alternate pin RB7
Maverick
Has thanked: 27 times
Been thanked: 8 times
Post by Maverick »
The attached code for PIC16F1789 (written under V9) is setup to direct DACoutput1 to port RB7 instead of RA2.
The code worked last time it was compiled on version 9. V10 simulator shows the correct value but a programmed chip does not. DAC Voltage is set at 3.1V, I measure 1.6V on RB7 (pin40) and 3.2V on RA2 (pin 4) which I am using as an input. I haven't clarified it but RA0 (pin 2) might not be working as an input as well. I have tried several micros including new parts ordered from RS this week.
Please advise solution
RBV80_ST_RIG_16F1789_V1-12.fcfx
(152.29 KiB) Downloaded 457 times
Has thanked: 635 times
Been thanked: 842 times
Re: DAC output not appearing on alternate pin RB7
Many thanks for letting us know.
It seems the DAC alt pin code was a late addition in v9 and had not made it into the code for v10 so it's now been added in for you via a library update.
Maverick
Post by Maverick »
Thanks Ben, worked fine
