Support for ADS1115 and ADS1118
OderlandoRSilva
Has thanked: 4 times
Been thanked: 6 times
Post by OderlandoRSilva »
Hello. I was thinking about using the ADS1115 and ADS1118 sensors, as they are very common and cheap. I saw an old post talking about the subject, but I saw that no components were created for the library. Has anyone managed to use these sensors using flowcode?
Has thanked: 724 times
Been thanked: 783 times
Re: Support for ADS1115 and ADS1118
I have just ordered one.
Hopefully, it will be added to the components this week, depending on the delivery day.
OderlandoRSilva
Hello. Is there anything new? I'm curious to know if it worked haha
Sorry for the delay.
I will hopefully be working on it soon.
Just an update.
I have got the component to work with any channel in single end mode and you can set the gain.
currently there is only a raw and voltage option.
You can read raw with channel 1 at a gain of +/- 6.144V for example and also read volts with a different channel and a different gain as they are set in the functions rather than the properties.
I'm sorting out the simulation side, then I will post the component for you to try
It currently is limited to ADS1115, as that is all I have to hand.
I have attached the component to try.
The Gains that are within properties are for simulation only and not hardware.
The Gains parameters are included within the SampleSglRaw and SampleSglVolts Function macros.
Simulation should be working OK
Please take in go account the component is work in progress.
To try the component.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Place the attached component.
ADS111x.fcpx
(8.07 KiB) Downloaded 428 times
