Pico Toolchain
Has thanked: 404 times
Been thanked: 625 times
Pico Toolchain
New laptop so installing everything fresh. I followed all instructions exactly on a clean machine running w11 and so far all good including esp 5.1....... which surprised me somewhat :)
However knowing even a slight change can really throw spanners in the work with 3rd party toolchain, when it came to the Pico toolchain when I click on the link I'm informed that the page is deprecated and to follow another link elsewhere. Is it "safe" to do so and by that I mean will it work or will it cause problems with the install?
Has thanked: 686 times
Been thanked: 759 times
Re: Pico Toolchain
Hi Iain.
the link is safe and the correct link to use.
The wording implies tool chain is no longer supported by the developer.
Later versions have not been tested on Flowcode, so might not even work.
If anyone decided to use later versions, then it will be at their risk.
Re: Pico Toolchain
Hi Martin
Thanks for the clarification. Having previously experienced a few nightmares when attempting to install different toolchains to recommended, I was a bit reluctant to just press on.
I'd forgotten how much of a pain setting a new machine up can be. All the unwanted stuff to be removed, wanted stuff to be installed then deciding which folders need to move too. Deep joy... but at least I'll be able to use App Developer (well I could on PCs but I hate just sitting at one) :)
Re: Pico Toolchain
Followed the guide and also installed latest git as part of the Pico install. Accepted everything not specifically told to change / ensure.
Didn't have access to any hardware but successfully compiled to hex.
Re: Pico Toolchain
That sounds like great news.
You should have no issues compiling to hardware.
Re: Pico Toolchain
That's my take too, and illustrates that on a clean W11 install, if you follow the guides exactly then they work.
