Ternary operator in calculation block?
MJU20
Has thanked: 105 times
Been thanked: 76 times
Flowcode v10 Ternary operator in calculation block?
Post by MJU20 »
Wouldn't that be a hoot?
val2 = (val1 < 20)?3:2
https://en.wikipedia.org/wiki/Ternary_c ... l_operator
kersing
Has thanked: 81 times
Been thanked: 65 times
Re: Ternary operator in calculation block?
Post by kersing »
Yep, that’s what I thought a couple of years ago as well. Got declined as being unreadable for novice users. Hopefully it will be reconsidered…
Has thanked: 174 times
Been thanked: 994 times
Post by mnfisher »
One trick I use a lot - allows an imitation of the ternary operator in a lot of cases.
Boolean operations return 1 for true and 0 for false.
So use:
.v1 = (.v2 < 20) + 2. // 3 if v2 is < 20 else 2
.flag = (.v == 10) // flag true if v = 10
kersing
Post by kersing »
Thanks for the hint, however strictly speaking false is zero and true might be any value not zero, so this working depends compiler/controller (and a bit of luck?)
Post by mnfisher »
True - but I've not had any issues so far. Also use if(.x) rather than if(.x !=0 ) - would be interesting to know if it actually saves any memory / or time. Must do a test...
It could come back to bite me someday :shock:
kersing
Post by kersing »
Any halfway decent compiler should optimize the expression, BTW, you probably don’t want to include a space between the exclamation mark and the equal sign as it should throw a syntax error. The correct syntax is if ( .x != 0 )
And in flowcode you can use <> which is easier on the eyes for novice programmers…
Post by mnfisher »
Autocorrect on my phone..
I read it as not(!) equal - nice that either works...
MJU20
Post by MJU20 »
Thanks guys for this input.
The trick from mnfisher I will remember, together with the remark that "false is zero and true might be any value not zero"..
As a non programmer readability is necessary for me, so I mostly use <>.
Flowcode is a nice program to not need to read code so the simpeler it gets the better.
But for an example like val2 = (val1 < 20)?3:2 there is a lot of commands needed..
I will start a Onenote to keep these tricks for me to remember.
