Hi!
The "Initialise" function never returns true.
The device does not reply.
After investigating with a logic analyzer,
I think the problem lies in the "Read Register Direct" function and the way you try to read from the device.
I noticed that
the trailing bytes you send after "command" and "address" bytes are all "0x00".
The device needs those bytes to be "0xFF" ,datasheet calls them "dummy bytes"
Please take a look at the code below:
//---- read a directly addressable registers  -----------------------------------------------------
unsigned long EasyCAT::SPIReadRegisterDirect (unsigned short Address, unsigned char Len)
                                                   // Address = register to read
                                                   // Len = number of bytes to read (1,2,3,4)
                                                   // a long is returned but only the requested bytes
                                                   // are meaningful, starting from LsByte
  ULONG Result;
  UWORD Addr;
  Addr.Word = Address;
  unsigned char i;
  SCS_Low_macro                                             // SPI chip select enable
  SPI_TransferTx(COMM_SPI_READ);                            // SPI read command
  SPI_TransferTx(Addr.Byte[1]);                             // address of the register
  SPI_TransferTxLast(Addr.Byte[0]);                         // to read, MsByte first
  for (i=0; i<Len; i++)                                     // read the requested number of bytes
  {                                                         // LsByte first
    Result.Byte = SPI_TransferRx(DUMMY_BYTE);            //
  SCS_High_macro                                            // SPI chip select disable
  return Result.Long;                                       // return the result
Best regards
George
						EasyCat-EtherCat component
				talig
