Hello together
My idea is the following
Everyone makes one or more files available to everyone with only a second loop, so that a collection of templates is created, which are published in the wiki, for example. Then you don't have to experiment with how a chip
how a chip has to be set up so that it runs for the first time. (Sec. Tackt) Or which C_Code must be, so that the USB port works with the PIC18F47J53. I would be happy if everyone would join in.
with kind regards
SpeedPIC32
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
- pic18f47j53_roh.fcfx
- (10.52 KiB) Downloaded 336 times
- (view online)
- Has thanked: 311 times
- Been thanked: 479 times
Re: My idea is the following
Thanks for the idea. We'd be very happy for you to post similar projects for other devices and you can do that on this forum.
However, be aware that the settings for getting a particular chip to work depends on the hardware configuration as well (for example, clock type, crystal value, etc), so there will not be a 'correct' setting for each chip.
