Hi Ben,
Thanks for your lines!
We can't daisy chain any of the LEDs, they are totally separate PCBs (some of them using WS2812 LEDs, others using WS2818 drivers) with their own PSU and go to physically opposite places for different parts of the system.
This was not a problem with FC9, FC8 before
For this project that was working fine in FC9, we have 3 different WS2812 components, but with some of the latest updates in FC9, it simply didn't work at all, then moved to FC10 and took me some time to figure out why it wasn't working
Also what do you do like in our case when we have 2x totally different components effectively (but in Flowcode is the same one):
1x WS2812B component (standard setting): which is
GRB encoded and drives 5V WS2812B LEDs directly)
1x WS2812 component (custom setting RGB as below): configured to communicate with RGB driver WS2818B which is effectively
RGB encoded instead of GRB driving 12V LEDs
- GRB.jpg (12.71 KiB) Viewed 6124 times
- RGB.jpg (17.18 KiB) Viewed 6124 times
I mean if you could at least have a second WS2812 component that would be great. Otherwise is it possible to have the WS2812 component source as maybe Martin could do some extra work to fix this for us
Thanks in advance!
R
