PICO GP IO Internal weak Pull UP Down
jay_dee
Has thanked: 101 times
Been thanked: 72 times
Post by jay_dee »
Playing with the PICO and its working well.
If I want a single pin (GP5) to be a input and set a weak pull up or pul down, how would I do this?
Does it need a line of C code?
I have a Switch component setup, set for Active Low. So I assume the Pin will be correctly set as an input.
Thanks, J.
Has thanked: 107 times
Been thanked: 302 times
Re: PICO GP IO Internal weak Pull UP Down
Try this C code
gpio_pull_up(5);
It might need to be placed after a Switch Read macro, which will initialise the pin for input.
jay_dee
Post by jay_dee »
Thanks, yep that works great.
Also found the pull down and pull disable (leave pin floating) commands.
test program attached for anyone else wanting to play along.
Also checked and the pull up is weak at around ~50K but works for my needs
IO_Pull_UPs_Enable.fcfx
(12.37 KiB) Downloaded 900 times
J.
