Support for the new PIC's and AVR's
DirkB
Has thanked: 1 time
Been thanked: 4 times
Post by DirkB »
I have the impression that there is currently only support for ESP32. I have to start a project with the Attiny84. But I can only buy the Attiny84A, for example. I can't get any usable results with this chip. There is no Uart, what about the USI? According to the data sheet, the USI generates an interrupt. What do I have to do to use the USI as a MIDI component? When will the new PIC's and AVR's, especially the small Attinys, be supported?
I have already posted two articles on this topic.
viewtopic.php?f=4&t=2192
viewtopic.php?f=4&t=2344
Many thanks
Dirk
Has thanked: 755 times
Been thanked: 817 times
Re: Support for the new PIC's and AVR's
Hi Dirk
I have created a new fcd for you to try for the Attiny 84A
Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
Note: you won't see any data within the fields when selecting Attiny 84A
DirkB wrote:
Mon Apr 29, 2024 9:14 am
Sorry, if you need to use UART then can you try a different target device that supports UART.
MIDI requires asynchronous comms and USI is for synchronous comms which is why its not used for UART
You could try the UARTT Software Timer component for Midi, but the Baud rates are limited to the timer interrupt frequencies.
ATTINY84A.fcdx
(14.63 KiB) Downloaded 486 times
DirkB
Has thanked: 1 time
Post by DirkB »
Hello Martin,
many thanks for that. Unfortunately there is an error message when compiling. I have attached the compiler message and test project. Do you have any ideas?
Thank you
Dirk
Attiny84A.fcfx
(12.12 KiB) Downloaded 452 times
Attiny84A.msg.txt
(8.09 KiB) Downloaded 620 times
Hi Dirk.
Your project is compiling OK for me.
It looks like you have the wrong toolchain installed.
The compiler messages are showing you have the Flowcode V8 toolchain.
You will need to go to here and sign in.
Download and install the Arduino/AVR toolchain.
If it is installed and still not working, then select File > Global settings... > Locations tab and make sure the path for AVR is
C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5
Also make sure your component library is up to-date.
DirkB
Has thanked: 1 time
Post by DirkB »
Hello Martin,,
the path was wrong, I don't know why. However, I still had to learn something about Fuse bits. Oscillator mode, CLK-Out and Clk divided by 8 can be taken out of the configuration. This is set with fuse bits. Now it works roughly. The sine signal from the PWM is not a smooth wave, but looks like a sine wave of small saw teeth. According to the data sheet, there are several PWM modes, normal mode, CTC mode, fast PWM mode and phase correct PWM mode. How can I set this? My component library is actually always up to date.
Thank you very much
Dirk
