PIC Random Nunber
jay_dee
Has thanked: 102 times
Been thanked: 74 times
PIC Random Nunber
Post by jay_dee »
Hi, this one has me stumped.
Is there a way to create a psudo random number, between limits in flowcode or via a C call?
I wish to create a delay with a random length between 0.5 and 4 seconds.
J.
Im using a PIC 18F 2585
Has thanked: 177 times
Been thanked: 1027 times
Re: PIC Random Nunber
Post by mnfisher »
Flowcode had random() and you could use something like:
500+(random() % 3500) to generate time between 500 and 4000 then delay in ms...
Has thanked: 478 times
Been thanked: 713 times
Generally speaking, yes, you can.
If you do a search in the forum you will find pleanty of info such as this
https://www.flowcode.co.uk/mmforums/vie ... 97#p106397
You might also want to include a truly random variable such as a temperature reading or an ADC on a floating pin to help mix it up :)
EDIT...
I see Martinn beat me to it :)
jay_dee
Post by jay_dee »
Ah Thanks Guys.
argh flipping heck..yeah found it now! Thanks Martin. :)
I did several searches on the current FC forum and did not find anything, FC is great on some of its features these days but sometimes even the simplest things are darn hard to find.
The "old" forum is a great source of knowledge going back to stoneage times :)
Post by mnfisher »
The issue with Random() is that the resultant sequence will be the same on every run. Great idea from Iain to use a 'genuinely random number (possibly as a seed) - for example current time in ms or a floating pin..
You can do this with a C Block and
srand(FCL_SEED);
Where .seed is the value you want to use as a seed (so something from an ADC etc)
Using the same seed is good for testing purposes - you get the same sequence every time - but may not be so good for games or other programs that rely on the user not knowing what is going to happen..
jay_dee
Post by jay_dee »
Fantastic, thanks. I have the standard random function working well, I'll try the srand C code tomorrow. :)
