I am using the servo controller set to 8 channels connected to port B on the 18F2480.
When I try to build to hex I get a CCP2 error. According to the data sheet there is only a CCP1 register in the device.
Can anyone shed any light as to why the XC8 compiler is trying to use CCP2 when it does not exist?
error: (192) undefined identifier "CCP2CON"
PIC18F2480 with the servo controller component
IanC
- Has thanked: 616 times
- Been thanked: 815 times
Re: PIC18F2480 with the servo controller component
Hello is it possible for you to use a more up to date version of the micro with 2 or more ccp available. The servo motor component uses two ccp peripherals on pic devices to do the servo motor timing.
