If then in a calculation
RGV250
Has thanked: 46 times
Been thanked: 45 times
Post by RGV250 »
I am a bit puzzled if this is possible or not, in the help for calculations it shows >, <, >= and so on but I cannot figure out how to use them.
I would like to be able to do simple things like
xyx = xyz + 1
if xyz > 10 then xyz = 0
So far I have had to do the addition and then use a decision which seems very cumbersome.
Inc and Dec would be a nice feature to add as well to make things tidier.
In a different program I can use
Inc xyz to increment by 1
or
Inc xyz,10 to increment it in steps of 10
Bob
Has thanked: 156 times
Been thanked: 906 times
Re: If then in a calculation
Post by mnfisher »
One for the first is
Xyz = (Xyz +1) % 10
Which will cycle back to 0 when Xyz reaches 10 - xyz = 0..9
RGV250
Post by RGV250 »
Thanks, that is a neat solution.
Bob
S_VE
Has thanked: 54 times
Been thanked: 2 times
Post by S_VE »
Good solution from martin
Just curious to know if we can use "IF.... THEN.... ELSE.... " directly inside CALCULATION
it will be very useful if we can.
S_V
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
Don’t you think using if then else in a calculation would change readability of flowcharts? Now looking at the icons you get a feel for the program flow. With if then else in a calculation you could create a obscured flow.
