The PIC18F47J53 has no PIN C3
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
Has thanked: 795 times
Been thanked: 858 times
Flowcode v10 Re: The PIC18F47J53 has no PIN C3
Many thanks for reporting the bug.
As you have not used the 9 or 10 post icon, I will assume you are using Flowcode V10
The attached FCD file is for Flowcode V10 only.
Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\
Replace the original file with the attached version.
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
I will modify all the other 18F4XJ53 fcdx files if the attached version is working ok.
You can also use SPI channel 2 which has remappable pins.
18F47J53.fcdx
(56.43 KiB) Downloaded 430 times
