Matrix Keypad Issues Disturbance
Danielrob306
Flowcode v9 Matrix Keypad Issues Disturbance
Post by Danielrob306 »
I am having issues setting up a matrix keypad using flowcode, I have wired up the columns and rows correctly and switched at the wiring multiple times but when I put my hand near my Arduino it starts reading random inputs and when I move it away it stops (this happens even when they keypad is not wired up, if I put my hand over the assigned ports) and also if I press the buttons on the keypad it doesn't do anything.
Here is my flowcode but I am sure that it is a problem caused by something else I have no idea how to fix.
(the loop in this code was just put to test reading the keypad inputs)
I would appreciate it if someone knows what is happening and could help me, I have two Arduino boards and have tried both, same issue.
Has thanked: 404 times
Been thanked: 625 times
Re: Matrix Keypad Issues Disturbance
That sounds like the inputs are floating (unconnected, no weak pull-up / down) and when your hand goes near, the capacitive effect is causing the inputs to change.
I'd confirm your connections to start with.
Has thanked: 686 times
Been thanked: 759 times
If you look at Generic Keypad on the Wiki, it shows you how to wire up the keypad.
kiroshia
Post by kiroshia »
Thank you I how can I use pullup/pulldown when it is a keypad connection, where would I put them
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
kiroshia wrote:
Sun May 19, 2024 8:27 pm
Have you checked the wiki link? It shows where to position the required resistors.
