Compilation error when using MFRC522 component with ESP32.[SOLVED]
Sasi
Has thanked: 43 times
Been thanked: 15 times
Flowcode v10 Compilation error when using MFRC522 component with ESP32.[SOLVED]
Post by Sasi »
I would like to ask for a little help.
I want to use the MFRC522 component with the ESP32 MCU, but I get a compilation error. I tried to change the component hardware settings in the Properties window, but the situation did not change.
Sasi
MFRC522_test.msg.txt
(21.21 KiB) Downloaded 630 times
MFRC522_test.fcfx
(11.9 KiB) Downloaded 564 times
Has thanked: 695 times
Been thanked: 767 times
Re: Compilation error when using MFRC522 component with ESP32.
Hello Sasi
Many thanks for the bug spot.
ESP32 is being over fussy.
I have fixed the issue.
To try the component.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Place the attached component.
RFID_MFRC522.fcpx
(14.41 KiB) Downloaded 477 times
Sasi
Post by Sasi »
Hi Martin,
Thank you very much for your help.
Compilation of the program is already working. :D
Unfortunately the MFRC522 component is not working and I don't know why yet.
Sasi
P.S.
Then all of a sudden it started working. It was probably a contact fault. It has been doing its job reliably ever since. Hooray! :D
