Syntax help
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Syntax help
Post by p.erasmus »
Hi Team.
in a normal C programming project I can define a number with and exponent like
#define _GAINFACTOR 1.87e-6
const GAIN = 1.87e-6
what is the recommend way in Flowcode , trying to create a constant with 187e-6 did not work or even 187exp(-6) :oops: :oops:
All help and pointers are appreciated
:D
Has thanked: 142 times
Been thanked: 761 times
Re: Syntax help
Post by mnfisher »
You could put it as a normal decimal?
0.000187
The form given is slightly odd - normally would be 1.87e-6 ?
p.erasmus
Re: Syntax help
Post by p.erasmus »
You are correct with that it is the old diabetes eyes miss such things lately
Yes I use the decimal form just thought there is a elegant way in Flowcode :D
p.erasmus
Re: Syntax help
Post by p.erasmus »
Hi Team.
I am struggling to understand how to compliment a byte a 16 bit variable ,
the value in the 16 bit variable is the two's compliment therefore it is necessary to subtract one from it and then do a compliment
I have been using this in CX8 in MPLAB by
int a = 10; /* 10 = 1010 */
int c = 0;
c = ~(a);
How can I do this in FC or even better obtaining the value from a two's compliment value :shock: with out the use of a C call :D
Has thanked: 214 times
Been thanked: 362 times
Re: Syntax help
In a calculation, the operator "NOT" is the ~ operator. It works in simulation and here's the code Flowcode produces.
    // Name: Calculation, Type: Calculation:
    // a = 10
    // c = 0
    FCV_A = 10;
    FCV_C = 0;
    // c = NOT (a)
    FCV_C = ~(FCV_A);
You might need to ensure you use unsigned bytes or unsigned ints.
p.erasmus
Re: Syntax help
Post by p.erasmus »
Thank you Steve.
Appreciate your help
p.erasmus
Re: Syntax help
Post by p.erasmus »
HI Steve,
A big thank you this worked great ,I am very happy see positive and negative temperature from the ADS1118 over SPI :D
