I2C Slave Pic12F1840 ( NOT FIXED )
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Flowcode v10 I2C Slave Pic12F1840 ( NOT FIXED )
Post by Alan_37 »
Trying to Communicate between an STM32F411 ( i2C Master ) and a PIC12F1840 i2C Slave .
I2C has 3 working Devices when I add the PIC18F1840 Slave and try to Scan for devices
it Replies with an ACK and then it shorts the SCK to GND and nothing works after that .
In my PIC Program I only INIT I2c and Put the MCU in a loop .
2024-06-17 19 36 02.jpg (13.89 KiB) Viewed 12125 times
2024-06-17 19 36 52.jpg (36.53 KiB) Viewed 12125 times
2024-06-17 19 35 40.jpg (63.35 KiB) Viewed 12125 times
Has thanked: 177 times
Been thanked: 1026 times
Re: I2C Slave ( Pic12F1840 )
Post by mnfisher »
I know this is for pic acting as slave - but see viewtopic.php?f=6&t=2598 - where we hit the same issue with connecting two AVR MCUs.
We got around by using the twi interrupt - and the pic maybe has something similar..
Post by mnfisher »
Also don't forget the pull up resistors!
Alan_37
Post by Alan_37 »
Hi pullup resistors where 10K and changed ro 4.7K
But Same problem
Alan_37
Post by Alan_37 »
mnfisher wrote: ↑
Mon Jun 17, 2024 7:35 pm
A Two wire interrupt , I think would be a custom interrupt , I am using i2c Channel 1 but I don't know how that would
work .
Alan_37
Post by Alan_37 »
Is this bug fixable or better look for an Alternative ?
Alan_37
Re: I2C Slave Pic12F1840 ( NOT FIXED )
Post by Alan_37 »
This Component Also does not work on Atmeg328P
Has someone ever seen this Component working?
Is there any plan to fix this Component any time soon?
Post by mnfisher »
The AVR example referenced above does work.
The slave needs to be interrupt driven to stand a chance.
Has thanked: 478 times
Been thanked: 713 times
Following on from Martin above, I was messing with I2C slave a while back and can't remember offhand when / why, but I do recall that I used the SSP interrupt on a PIC (not every PIC has this feature). Can't really remember much more, or if I actually succeeded in doing what I wanted, but I do know that I had to use the SSP.
If you go to the "old" forum and search for I2C SSP you should find some information. Incidentally the old forum is a great source of help.
https://www.flowcode.co.uk/mmforums/sea ... ds=i2c+ssp
