Static Local varialbles
S_VE
Has thanked: 54 times
Been thanked: 2 times
Flowcode v9 Static Local varialbles
Post by S_VE »
is there any way to create a STATIC Local Variables within the macro?
so that the variable retains the value even after exiting the macro.
this is the same as we use in C Program.
( this is to avoid cluttering the Global Variable section )
-S_Ve
S_V
Has thanked: 156 times
Been thanked: 906 times
Re: Static Local varialbles
Post by mnfisher »
There is - but it is a little bit 'clunky'
See viewtopic.php?f=3&t=1509&hilit=static&p=8672#p8672
S_VE
Post by S_VE »
Thank you Martin
but does this method take one extra variable (data memory), and few more cycles ?
very useful workaround . Thank you.
S_V
