Hello?
I have a question about PID Control.
I have two motors. The two motors have different speeds and gear ratios.
So I want to make the speeds of the two motors the same.
Motor A accelerates and decelerates. However, the speed change is not large.
I want Motor B to drive at the same speed according to the speed change of Motor A.
Motor B is a BLDC motor. It can be controlled by duty ratio.
I can read the speed value (Count Value) of Motor A and the speed value (Count Value) of Motor B correctly.
The count value of Motor B is twice that of Motor A.
I want to control the duty ratio of Motor B through PID control by referencing each count value.
Is it possible?
Please help me.
Thank you.
I need help of PID Control
seokgi
- Has thanked: 8 times
- Been thanked: 8 times
- Has thanked: 697 times
- Been thanked: 767 times
Re: I need help of PID Control
Hello this will be a good starting point for you as there are PID examples.
This is a link to Process Control Curriculum, which is all about PID
