Timer Interrupt
jollybv
Has thanked: 41 times
Been thanked: 12 times
Timer Interrupt
Post by jollybv »
Hi Guys
If I'm using timer interrupt 4 on a PIC18F46K80 which is set to 125 Hz how do i work out how many times it will need to call the macro to give me a 1 second pulse? I worked out about 8000 but when i tried it and tried to count to 30 minutes (1800 seconds) it was not very accurate. Any help will be much appreciated
Has thanked: 267 times
Been thanked: 432 times
Re: Timer Interrupt
An interrupt at 125 Hz means it is being called 125 times each second. If you use a global variable initially set to zero and incremented each time within your interrupt routine, then when it reaches 125 then that should be 1 second.
Remember to keep your interrupt routine as short as possible. For example, only increment the variable within the interrupt routine itself. Then, in a convenient place in your program's main loop (i.e. somewhere that is frequently executed), you can check this variable and if it has reached 125 then you know 1 second has elapsed. As this point, reset it back to zero and process anything that should happen when this time has elapsed.
jollybv
Re: Timer Interrupt
Post by jollybv »
Hi Steve
Thanks for that let me give it a try
