I'm getting a connection error during the update process, how should I handle this?
niedian
- Has thanked: 3 times
- Been thanked: 5 times
Hello, I am a Flowcode 10 Professional user. I am encountering connection errors when trying to update my program. Could you please advise on how to handle this?
- Snipaste_2024-07-11_19-42-24.png (38.02 KiB) Viewed 4323 times
- Snipaste_2024-07-11_19-42-07.png (36.27 KiB) Viewed 4323 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: I'm getting a connection error during the update process, how should I handle this?
Hello, Select File > Global Settings... > Application tab
Have you got Enable ticked for Web access?
- Has thanked: 292 times
- Been thanked: 458 times
Check your "Web access" options in Global Settings. In most cases this should enabled and set to "Direct Access".
If there's still a problem, maybe a firewall or similar on your PC is preventing Flowcode from accessing the internet.
Thank you, but the problem still hasn't been resolved. I plan to reinstall the operating system in a few days and then try installing Flowcode 10 again.
