Hi Matrix Dev,
I believe it looks like MQTT Qos is currently using Qos 0, if possible
Can you add a function to change the QOS on the MQTT client component in runtime?
sandinug
can add change Qos mqtt client
sandinugraha
- Has thanked: 4 times
- Been thanked: 2 times
- Has thanked: 575 times
- Been thanked: 757 times
Re: can add change Qos mqtt client
It looks like we specify MQTT v3.1 when performing a publish which is prior to the QoS functionality. I'll investigate and see if we can move the component to 3.1.1 which includes the QoS bits and also what additional this would require.
- Has thanked: 258 times
- Been thanked: 413 times
Just to add to this, the MQTT Client component used in Flowcode Web Developer already supports QoS (as a parameter in the macro to publish a message).
