Using the timer component on esp32.
GetRawCount ("gets instruction count") actually returns number of default time units (so for a standard timer on timer 0 - this is 1ms units)
It is possible to get the instruction count using xthal_get_ccount() in a code macro. This increments and about 240MHz (on my esp32 with a 1s delay I got 239971173 counts)
I wanted to check if >1us had passed since previous interrupt (so count >= 240)..
Esp32 timer issue
- Has thanked: 156 times
- Been thanked: 902 times
- Has thanked: 590 times
- Been thanked: 778 times
Re: Esp32 timer issue
Hi Martin,
Ooh thanks I'll see if we can use this function instead, that would be much better.
