V10 FLOWCODE BUG BUTTON SYSTEM CRASH
KJWILLOTT
Post by KJWILLOTT »
Hello to steve tandy using flow code v10 run simulation ok
go back to bug icon click to go to stop simulation button. Before i get to stop button flow code crash
it takes me out of flow code v10 then I go back in start again this happens with all projectS
I HAVE ASUS VIVOBOOK INTEL PENTIUMGOLD 7505 8GBITE RAM256GB SSD WINDOWS 11 PRO 2 COREES 3.50 GHHZ MAX
CANYOU ADVISE I THINK THIS MAY BE SOFTWARE PROBLEM HOPE YOU CAN HELP MANY THANKS KEVIN
Has thanked: 247 times
Been thanked: 402 times
Re: V10 FLOWCODE BUG BUTTON SYSTEM CRASH
Sorry for the late reply - I have been on holiday for the past 2 weeks.
When Flowcode crashes, you should get a window to submit a crash report. Has this happened?
Because this is happening with all projects, I suspect there is some other app on your PC that is interfering with Flowcode. Please try running Windows in safe mode and try Flowcode again. Alternatively, look at the logs of any security software you have installed to see if they are causing the problem and maybe add Flowcode as a 'trusted app' in their settings.
KJWILLOTT
Post by KJWILLOTT »
thanks steve will give it a try
