Advice!
Has thanked: 758 times
Been thanked: 187 times
Flowcode v10 Advice!
Post by jgu1 »
Hi all!
I am making a project where I use PWM. I want to adjust the timing with two button. I call these two button by help of pin interrupt to toggle up and down. I in/de crement by one (in the calculation DelayAjd = DelayAjd - 1 and DelayAjd = DelayAjd + 1 But every time I press one of the button the counters step up and down with two? If I change cslculation with 2 it change with 4 ?
Works in simulation. My loop in the interrupt I use for "delay" timer to avoid noice. I know it is not good to use delay component in macro called by interrupt.
Plaese, what am i doing wrong? :roll:
Br jorgen
Generator.fcfx
(25.05 KiB) Downloaded 205 times
Has thanked: 147 times
Been thanked: 803 times
Re: Advice!
Post by mnfisher »
In Up and Down - you can get an infinite loop.
For example if DelayAdj is 0 when Up is called - then it will loop to connection point A forever.
Can you use a button component?
Re: Advice!
Post by jgu1 »
Hi Martin :D
Honest, I don’t understand,
I dare to ask, Will you please to edit in my program, Then I would be happy :D
Re: Advice!
Post by mnfisher »
A first idea.
Here I read both buttons and then adjust DelayAjd - no change if both buttons pressed.
I just print the value to LCD - so 'works' in simulation. Then wait for buttons to be released (or have a delay for value to increase / decrease whilst button held)
It would be nicer - at least in simulation - to use an interrupt. In simulation button presses can be 'missed' (probably whilst waiting for 'low') - but I don't think this will be an issue on hardware which is rather quicker?
I commented in 'Up' where the infinite loop can occur...
Gen2.fcfx
(29.33 KiB) Downloaded 212 times
Re: Advice!
Post by jgu1 »
Thank you Martin, I see now what you mean, and it work. Now I can continue :D
Jorgen
Re: Advice!
Post by mnfisher »
Good to hear you are going again.
Please let us see the project when it's running 👍
Re: Advice!
Post by jgu1 »
You Will hear Martin, take a little while. ;)
