V4 to V10 code
Igneia
V4 to V10 code
Post by Igneia »
I've lots of code in Version 4 and was looking to finally upgrade to V10. Will I be able to open V4 code in 10 or am I looking to have to rewrite from scratch?
Has thanked: 429 times
Been thanked: 647 times
Re: V4 to V10 code
Unfortunately you would need to first open your v4 in v7 then save. You could then open in v10
Due to travel I can't do that for you but I am sure others will offer to assist.
You might need to tweak your new v10 files after conversion but nothing serious.
Has thanked: 267 times
Been thanked: 432 times
Re: V4 to V10 code
The biggest issue you will face is with components. There are massive differences between the components (their properties and functions) between v4 and v10.
Igneia
Re: V4 to V10 code
Post by Igneia »
OK But I think V10 will import C code, can I save in C for V4 then import that C code into V10?
Re: V4 to V10 code
Yes, I suppose that is an option. As long as the C code is compatible with the compiler used by Flowcode v10. Also note that simulation is unlikely to work well if you use a lot of C code.
