PWM FC component for ESP ?
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Flowcode v10 PWM FC component for ESP ?
Post by Xbiotec »
hi,
which FC component is better to use for PWM on ESP32 ?
Seb
Xbiotec
Re: PWM FC component for ESP ?
Post by Xbiotec »
Hi FC team, no answer for this question?
Seb
Has thanked: 724 times
Been thanked: 783 times
You have posted a question in User Components.
User Components.png (24.58 KiB) Viewed 7919 times
I have moved your post to general as you have not created a component
There is a dedicated PWM component within the Outputs of the component library.
Or you can select the component library ribbon, then click on the magnifying glass and enter PWM.
Xbiotec
Post by Xbiotec »
Hi Martin,
I know that there components already made but there is :
- PWM (cal)
- PWM (internal) it seems that "Set frequency" do not work
So which one is adapted to EPS32 ?
also need to be able to change Frequency, dutycycle with a variable.
Seb
We don't recommend using cal which is why I mentioned dedicated PWM.
I also mentioned where the PWM component is as its helpful for new Flowcode uses that will read this topic.
Thank you for letting us know the set Frequency is not working, we are investigating the issue and will be fixed ASAP
Xbiotec
Flowcode v10 Re: PWM FC component for ESP ?
Post by Xbiotec »
Set frequency do not work on FC PWM (internal) component.
Please also check duty cycle because I need to setdutycycle10bit to 32 to get 50% duty cycle .
What must be the max value for period overflow ?
please make ti working ASAP. thx
Seb
Xbiotec
Post by Xbiotec »
hello,
still no news?
Seb
There is not always a quick fix as an update can break other target devices.
I will post on here when the PWM has been fixed.
Xbiotec
Post by Xbiotec »
I know Martin that there is not always a quick fix but you can understand that I don't know if your are working on it or not,
and as you know for professional use, we can not only ask and wait...
thx
Seb
Xbiotec
Post by Xbiotec »
medelec35 wrote:
Mon Oct 07, 2024 11:19 am
No, not since https://flowcode.co.uk/forums/viewtopic.php?p=17327#p17327
hello Martin,
this link is wrong.
Seb
