CAN Filter Changes on the Fly.
jay_dee
Has thanked: 101 times
Been thanked: 72 times
Post by jay_dee »
To ensure I capture the latest CAN data from a fast and busy datastream, I am setting the Mask to check all bits (2047) and Filter for a specific single ID,
Then progmaticaly changing the filter value and stepping through the three message ID's I require.
It seems a bit cumbersome but I cleanly get all messages updated.
(I can already see that with my method if one messge stopped being transmitted the system would brick, but i can add a work around for this)
Question: When I set the RX Filter (SetRxFilter 0), does this clear the RX buffer of old data?
Or should I also check the Rx Buffer first, as I believe this will clear the RX buffer.
CAN Macro is attached.
Thansk, j.
CANRx0_V4-1.fcm
(8.7 KiB) Downloaded 459 times
Has thanked: 642 times
Been thanked: 850 times
Re: CAN Filter Changes on the Fly.
Sorry for the delay in getting back to you.
Changing the RxFilter will not remove any already received messages from the buffer.
jay_dee
Post by jay_dee »
Thanks Ben,
Are you aware of any command that will flush the buffer?
Does the Check RX buffer command? I have no real idea but I thought it may read the hardware buffer (MCP2515/ECAN) into a local FC macro software buffer?
J.
