Hi!
I start a project with display ESP32-dev1 and ST7735 display, During startup I always make a test.
I cannot compile, syntax error, please what am I doing wrong?
Br Jorgen
Display St7735
- Has thanked: 839 times
- Been thanked: 205 times
Display St7735
- Es.msg.txt
- (443 Bytes) Downloaded 184 times
- Es.fcfx
- (15.18 KiB) Downloaded 179 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: Display St7735
Hi Jorgen.
The issue is being caused by a pin not being connected.
In this case it is the Reset pin.
Even though you have selected No for use reset, it still requires a pin.
You was not to know as the pin selection was hidden.
I will chat to a colleague today and see if there is something we can do about that.
In your case select Yes for use Reset, select an unused pin, then change it back to No
Re: Display St7735
Hi Jorgen.
That's great!
I have modified your St7735 component so they any unused pins are assigned to a pin, so you don't get this issue again.
I'm just awaiting feedback about it form a colleague (i have only just sent the email, so it might be tomorrow), then I will post it on here for you to try.
That's great!
