PCF8574 compile error
malivdls3
Post by malivdls3 »
hi everybody
I try to send a byte to the I2C port expander with the PCF8574 component, but I always get an error when compiling. Reading port works normally but write port cant compile.
Flowcode "https://ibb.co/845k9dY"
PCF8574 component.fcfx
(8.29 KiB) Downloaded 373 times
compiler error
Employing 18F4550 errata work-arounds:
* Corrupted fast interrupt shadow registers
v10bwr.c: FCD_02c31_PCF8574__WritePort()
200: FCD_05bd1_dash_IO_flasher1__FlashTx();
^ (361) function declared implicit int (warning)
using updated 32-bit floating-point libraries; improved accuracy might increase code size
0: (499) undefined symbol:
_FCD_05bd1_dash_IO_flasher1__FlashTx(v10bwr.obj)
(908) exit status = 1
please help thanks in advance
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: PCF8574 compile error
Post by p.erasmus »
It is always better with such compile errors to attach your Flowchart to the post you make ,it helps people to see what is going wrong
use the attachment button to add your flowcode chart
