How can we use the esp now protocol with flowcode?
ayhan1
Has thanked: 18 times
Been thanked: 2 times
Post by ayhan1 »
How can we use the esp now protocol with flowcode? How do we communicate two ESP modules directly with each other?
ARK2908
Has thanked: 1 time
Re: How can we use the esp now protocol with flowcode?
Post by ARK2908 »
This is my question too, it would be nice if we could get a clear answer from the Flowcode team in the near future!
Has thanked: 795 times
Been thanked: 858 times
Thank you for the suggestion.
We have added it to out list and are looking into it.
ayhan1
Post by ayhan1 »
medelec35 wrote: ↑
Thu Oct 17, 2024 11:03 am
This is great news. I hope it will be added to flowcode soon. :)
Has thanked: 177 times
Been thanked: 1026 times
Post by mnfisher »
For fun - I got esp_now up and running...
It's a little bit involved - and you'll need 2 (or more) x esp32 (any type) boards.
I just output data to UART - and in my case I have COM4 as my sender and COM7 as a receiver - if required both ends can send and receive.
I would recommend using the 'old' batch files that create a new directory for each program - and if you have used the new 'install' for 5.3.1 you'll need to modify C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat to set
DOS_BUILD_DIR to %OUTDIR%%TARGET%
Near the beginning of the file.
Save the attached program - DO NOT call it espnow.fcfx (this will lead to heartache and other problems)
Attempt to compile it (this will fail)
Open a command prompt - and cd to the program directory (if you saved as c:\fcespnow.fcfx this will be c:\fcespnow)
Run export.bat (I have this at C:\Espressif\frameworks\esp-idf-v5.3 - if you used the FC install this will be different)
idf.py add-dependency "espressif/esp-now=*"
idf.py fullclean
idf.py build
You should now see the espnow component get added at the start of compilation.
idf.py menuconfig -> esp_now has been added to components
There is a global constant - SENDER - set to false for the receiver, true for the sender.
Now compile and upload to your 'receiver' - open a com port (I use PuTTY) - and make a note of the MAC address which is displayed.
Modify the array 'receiver' (to the receive MAC address) (this is a local in main) and compile and upload to your 'sender'
Now you should get Received from MAC aa bb .. ff -> 01, 02 .. 00 (every 1s) if all is well. The array 'rotates' each time for a little extra excitement.
I think this could convert to a component fairly easily - there is the issue of the receive callback (because of the way FC handles arrays I use a ULONG as the MAC and data parameters) - but it would be possible to have a SetReceiveCB that takes the address of a FC Macro - but this will need a minimum of one line of C code..
Note that esp_now allows data of up to 250 bytes to be sent as one packet...
FCEspNow.fcfx
(24.55 KiB) Downloaded 519 times
Post by mnfisher »
Bi-directional transfers work AOK - but the MAC shown as part of the receive isn't the same as the actual MAC (displayed at the start of the output)
So use the MAC displayed at start - and note that the added receiver MAC and the Send MAC must be the same for it to work...
Will maybe try an extra board :-)
One board sending to many (well 2) also works. (AddReceiver for each then Send to each MAC)
ayhan1
Post by ayhan1 »
mnfisher wrote: ↑
Sun Oct 20, 2024 4:14 pm
idf.py fullclean
idf.py build
Thank you. I will try
ayhan1
Post by ayhan1 »
mnfisher wrote: ↑
idf.py fullclean
idf.py build
I couldn't do this. I didn't understand the steps. Can you give a simpler explanation?
Post by mnfisher »
How far did you get?
I'll try and expand on the bit you are stuck on - it's a fairly advanced project, but once you have it compiling it's not too bad..
Post by mnfisher »
I did a quick video of this being setup and compiled to a receiver and a sender. You will need to have the espressif tools setup and be comfortable using them from the command line. Here it is set to create a new directory for each program (FCNow3 - my first couple of attempts recordings were rather fuzzy :-( )
https://www.youtube.com/watch?v=szfqEMHYOpk
My hat is off to anyone who edits videos! So it is not very polished ! It is however in roughly real time (I cut the compile sequences, even though they are exciting to watch!)
I think it would be possible to have a 'known' master - and then add slaves - that transmit their MAC to the master as the first contact. Then the user could add multiple slaves without having to recompile the master program..
