CALCULATE BPM FROM RAW DATA OF MAX30100 SENSOR
SILVESTROS
Has thanked: 32 times
Been thanked: 2 times
Post by SILVESTROS »
Hi to all !
I would like to calculate HEART RATE (BPM) and SpO2 (%) from raw data of a MAX30100 sensor. Is there an example in FC10 to help me for that ?
Basil
Has thanked: 696 times
Been thanked: 767 times
Re: CALCULATE BPM FROM RAW DATA OF MAX30100 SENSOR
Have you see this webpage?
If you look at the code, it is just timing the duration of each reading.
You can use the Component Libraries > Math > Timer component for that.
Once you have the duration in ms of time between beats you can use a calculation command icon with:
beatsPerMinute = 60 / (duration / 1000.0)
