Acs712 with St7735 Display!
Has thanked: 696 times
Been thanked: 183 times
Flowcode v10 Acs712 with St7735 Display!
Post by jgu1 »
Hi all!
Yes it´s me, who need help again, hope it´s ok :lol:
Using an Arduino Mega, ST7735 display and an ACS712.
To avoid flicker as much as possible in the display I only update when Amp is changing so I use " If new <> from old write the new and update Old"
It work fine in simulation , but in real world it update all time, without changing amp? Same issue with the ILI9341 display, but working fine with a
LCD display 4X20 serial. very stable.
I have try to use all kind of capacitors over the supply, ect.
Am I doing something wrong in my examble, or is there another way I can avoid or solve the problem or "flicker during update value", please.
Thank´s in advance
Jorgen
DispUpdate.fcfx
(18.26 KiB) Downloaded 137 times
Has thanked: 142 times
Been thanked: 761 times
Re: Acs712 with St7735 Display!
Post by mnfisher »
I would guess that the current reading is fluctuating enough to cause a refresh.
Maybe check if AmpOld and Amp differ by a certain 'threshold' amount and see if that helps?
Post by jgu1 »
Hi Martin!
Know I could count on you ;) Thank you.
Already tested, no matter if I ground the ACS712 or use a battery, its always update, strange?
Post by mnfisher »
How quickly does the sensor refresh? - maybe add a delay in the loop. It will surely help - but maybe not in the right way (1s delay == 1s refresh)
Amp and oldAmp - are floats, cormparing them for equality might not work well..
Something like abs(oldAmp - amp) > 0.1might do the trick?
Would need to be fabs (#include <math.h>) or create your own (if(x < 0) return -x)
Post by jgu1 »
“Amp and oldAmp - are floats, cormparing them for equality might not work well..”
What i also thought, I try to change to byte 0-255 for test, same.
I Will test your suggest later today, you hear, Thank’s.
Br
Jorgen
Post by jgu1 »
I placed this in an calculationbox before compare
AmpOld = (AmpOld - Amp) > 0.1 rigth or ?
But still the same :? Neither the delay solve the issue.
Post by mnfisher »
Need to check if its negative as well (> -0.1 (hence the fabs - which would need to be in a C block)) - can you print out the readings? Do they look reasonable?
Post by jgu1 »
Hello MArtin!
Sorry take your time. When I remove the USB programming cable from the arduino it get much more stable :lol:
So this have some disturbtion on the reading. Thank you for your always helping.
Br Jorgen
Post by mnfisher »
Sounds like an interesting (and sensitive) sensor...
Good that you are getting some readings now.
Some displays are also very 'noisy' - I had issues with an SSD1306 - which introduced a huge amount of hum into a circuit.
