ST7796 reset pin connected ESP32 reset
OldHound
Post by OldHound »
I'm using a cheap yellow board (ESP32-3248S035C) which has a ST7796 display controller.
The reset pin of the ST7796 is connected to the ESP32's own reset. I don't know how to set its use in the connections values for the component - setting it to Unconnected gets me a syntax error when I try to compile.
If I set the reset pin to one of the other (currently unused) I/O pins it will compile but it seems that there should be a better way to configure the reset. Any suggestions?
Has thanked: 756 times
Been thanked: 819 times
Flowcode v10 Re: ST7796 reset pin connected ESP32 reset
I have added Use CS, and Use Reset to the properties.
When you select No the the pin will automatically be assigned, so should not cause any compile errors.
Can you try the attached and see if it works better for you.
If it does the it will be added to the component database.
%ProgramData%\MatrixTSL\FlowcodeV10\Components
Place the attached component.
gLCD_ST7796_SPI.fcpx
(19.92 KiB) Downloaded 304 times
Fixed issue that prevents display from working on non ESP32 target devices.
(19.87 KiB) Downloaded 319 times
