Any plans to include some communications to industrial controllers such as Ether-Cat and Ethernet I/P?
Thanks,
Karl
Industrial Communications
KARLGROSS
- Been thanked: 1 time
- Has thanked: 523 times
- Been thanked: 710 times
Re: Industrial Communications
Hi Karl,
I beleive both are currently supported.
Hi Ben,
Can you point to a place to find the component for the Ethernet I/P?. This is an industrial protocol for communication in real-time applications just as Ether-Cat is a protocol. Goggle short description is "EtherNet/IP (Ethernet Industrial Protocol) is an industrial networking standard that uses Ethernet for communication between industrial devices. It allows devices like PLCs, sensors, and actuators to exchange data in real time using TCP/IP and UDP/IP protocols, making it suitable for factory automation and process control."
Do you have such a component?
