MCP41HV51
Has thanked: 839 times
Been thanked: 205 times
Flowcode v10 MCP41HV51
Post by jgu1 »
Hi all!
I've looked in the Wiki for an example of this component, but there isn't one. I just ordered a few, get them next week.
https://dk.rs-online.com/web/p/analog-u ... 67473?gb=s
Does anyone have experience with these? I have tried to make a testprogram myself, am I on the right track, could someone have a look at my testprogram, please?
br Jorgen
MCP41HV51.fcfx
(16.15 KiB) Downloaded 234 times
Has thanked: 442 times
Been thanked: 661 times
Re: MCP41HV51
Hi Jorgen
Does this post help?
viewtopic.php?t=2369
I could be wrong but doesn't the component MCP45xx work (xx being don't care)?
Re: MCP41HV51
Post by jgu1 »
Hi Chipfreyer!
Thank you. Very nice, but I am looking for an examble how to use the component, maybe you could have a look at my examble it seem to work i simulation, am I on the right way? :D
Jorgen
Re: MCP41HV51
Post by jgu1 »
Hi !
SPI model.
I get ny board. I have perform a test. No matter what I do I can´t get i work. Same for CH1 and SWmode. When I measure with my scope no data on any SPI pin.?
*****EDIT: After set index to 1 I see now data on the SPI pin? But I am not able to see any change on the POT PoA and POW and PoB **
https://docs.rs-online.com/be55/A700000007461615.pdf
Have any expeience with this device, not sure if I do something wrong, please. New tesprogram att.
Hope for help :)
Jorgen
DigipotTwo.fcfx
(17.42 KiB) Downloaded 218 times
Digipot.fcfx
(16.25 KiB) Downloaded 220 times
Has thanked: 724 times
Been thanked: 783 times
Re: MCP41HV51
Hi Jorgen.
the MCP41XXX would refer to any three numbers after the 41.
Like wise with MCP41XX would refer to any two numbers after the 41.
As they are both different components, then they both will work differently.
The MCP41HV51 are a mixture of letters and numbers, therefore I would again assume it works differently.
You could try the MCP41XX, but I can't say if it will work or not?
If it does not work, then currently the MCP41HV51 is not supported.
If you can let me know, so we can look at adding the component for you.
If we need to add it, I don't have the board to test with, so I will need to order one.
One thing to note with your Flowchart.
You have got the debounce set to 5ms.
Debounce only works with the Switch functions and not with inputs.
If you want to use the debounce option then you will need to swap the inputs with ReadState function.
Also, don't forget the pulldown resistors for the switch
Re: MCP41HV51
Post by jgu1 »
Hi Martin!
Again thank´s. I will test your suggestion during the weekend :D
If it not help I can send you one of my MCP41HV51 board and you don´t have to return it, keep it, no problem.
You hear, nice weekend :D
br jorgen
Re: MCP41HV51
Post by jgu1 »
Hi Martin!
Yes, you are the Master :D I change to one of the other with only XX and not XXX and it work,so fine.
If you want, my offer is still open and I can send you one board ? ;)
Br jorgen
